Community Member
Attendance Console With CUCM 7.1
Hi Experts,
I would be greatfull if some one can help in this.
I have a cluster of two CUCM 7.1 newly installed and I tried to activate attendance console, everythings look nice, but when I try to open the AC from my PC the message " Invalid Password, please try again"
Please if there is special configuration for CUCM 7.1 , coz I tried the configuration of CUCM 6.0.
Thanks.
Re: Attendance Console With CUCM 7.1
Not really, it's the same config on 6.X or 7.X
Recreate the AC user you're trying to log or use another one
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
I tried many times but nothing. Can you send me the configuration, Please
All the guides are available on CCO if you search for them
Cisco Unified Communications Manager Attendant Console
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsccmac.html
java
java
Silver
Have you tried to restart the "TCD" and "CTI Manager" services?
Also install AC in another PC and try it again. Verify that the local Administrator account has this right, if not, add the local Administrator account then retry the installation.
MK
250
