attendant console and ccm 4.1.3
hi
i got ccm 4.1.3 and trying to install attendant console for the operator
operator has 7960 ip phone (DN= 5082)
i cretaed < ac > user in the global directory and checked the box >> Enable CTI Application Use and Call Park Retrieval Allowed .. also associated this user with 7960 ip phone number 5082 and attendnat console pilot number 5098.
also i created a attendantconsole pilot number which is 5098
and created hunt group . and add attendantconsole pilot number as a member of this hunt group(5098)
and also i installed console client into the operator pc/ i can login to attendant console program and also i can see directory is ok ..but when i try to dial any extension i got an error ' no lines available to make a new call'
also if i try to call number 5098 from any ip phone the call fails and gives busy signal
also most of the buttons of the attentconsole are invisible.
any idea pls. also i can share printscreens if anyone needs.
thanks a lot
  • IP Telephony
Re: attendant console and ccm 4.1.3
For ac user you create password 12345 or different ? if different you need to change ac user password on ccm -- acconfig.bat
it wasnt but now i changed the password as 12345
global username ac
password 12345
Attendant Console User username aacon
password 12345
but it is same, nothing changed
94
