Attendant Console and CUCM 8.5.1
Will the version of AC that shipped with CM 7.1.3 work with CM 8.5.1?
Is there a newer Attendant Console version built in to CM 8.5 ir did that finally do away. We've been a CM site since ver 3.x and have been using the built in plugin versions of AC since then.
Patrick
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Sorry Patrick, but unfortunatelly no, AC was removed from CUCM in version 8.0 completely, no more AC service.
You now need to buy AC and run it on a separate server ot VM instance.
There are few different variants of it now and you can see the details under the attendant console product page.
HTH,
Chris
HTH,
Chris
Bummer.
Thanks for the quick reply.
525
