Community Member
Attendant Console and CUCM 9.1.2
I performed migration from CUCM 7.1 to CUCM 9.1 and now i cannot connect to server from attendant console - unable connect to server.
I know that Attendant Console is not supported on 7.1 but it worked.
Will CallManager Attendant Console work on CUCM 9.1.2 after migration from 7.1 ?
Re: Attendant Console and CUCM 9.1.2
No, support for Cisco AC is completely removed in 8.x and above.
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
Thank you, do you know maybe there is replacement for this tool. Our customer want to control thier phones from computers.
Is it possible to completly control Desktop IP Phone from cisco jabber like  from attendant console?
Thanks in advance,
with best regards
If you only want phone control you can do that with Jabber.
You can also look into the CUxAC products
java
if this helps, please rate
www.cisco.com/go/pdi
Also ANDTek has a good variant of a AC, but as stated before if you only want desk phone control you can use Jabber.
390
