Attendant Console directory list
have installed Attendant Console, can the directory list be updated from Callmanager.
Currently I have Callmanager synced with an Microsoft AD (LDAP) server, so the end users are pulled in from AD, can this also be pulled in to the Attendant Application?
Hope you can help.
N.
1 ACCEPTED SOLUTION
Re: Attendant Console directory list
Just a quick question, what CUCM version are you guys using? because generally, all users defined in the CUCM End User page can be pulled out in the AConsole, searching the tab to show "all users" the Names and extensions must be seen, in your case the end users are being populated using LDAP, meaning the user should also appear in your AC.
Dennis
Dennis
Version 6.1
have just tried this and it works,
thanks for your
Norm
148
