Community Member
Attendant Console directory problem
I have a customer who used the CorporateDirectory.txt file to import the CallManager users initially. Now he complains that when he adds a user to CallManager, the change is not reflected in the Attendant Console's directory.
I also found out that the CorporateDirector.txt file is not there, as I get an error when I try a User File Upload.
My basic question, however, is how can I revert to normal operation, that is, to have changes in CallManager update the Attendant Console's directory without having to use the file upload method.
Your help would be appreciated.
Denis
Green
Re: Attendant Console directory problem
Hi Dennis,
You may delete the CorporateDirectory from PC
C:\Program Files\Cisco\Unified CallManager Attendant Console\userlists
then restart the AC service to force a new file to be generated. No need to have CorporateDirectory in Server
Also check traces in ACClient
C:\Program Files\Cisco\Unified CallManager Attendant Console\logs
It will tell something for CorporateDirectory
Community Member
I totally forgot to mention that the customer is running CM version 5.1, so I don't know where that file is.
Denis
361
