Community Member
attendant console for CME (ARC express is end of life)
I would need an Attendent Console solution for CME but unfortunately ARC express is not available anymore...
Is there other AC I could use with CME?
Thanks!
Tibor
1 ACCEPTED SOLUTION
Bronze
Re: attendant console for CME (ARC express is end of life)
Good Day,
One option would be SCC 1.6
(operator console) as it is still supported with CME. The
nuance is that it is only with the UC platforms. But there
is a plan to support customers looking to use it with CME/ISR.
And that option should be available in the coming weeks/months.
Bronze
Good Day,
Community Member
Thank You for the information and your help!
Tibor
570
