03-13-2012 04:05 PM - edited 03-16-2019 10:06 AM
Hi All,
I was just wondering if the free attendant console gets brought back in the later versions please?
We are runnint 8.0.X but moving to upgrade to 8.6 soon.
thanks
amanda
Solved! Go to Solution.
03-13-2012 04:18 PM
Amanda,
Unfortunately the answer is no, and as far as I know there are absolutely no plans for it. I suggest you contact your Cisco Account Manager to voice your disappointment.
HTH,
Chris
03-13-2012 04:27 PM
Hi Amanda,
Sorry but its gone
EOL Link
You now need to use the replacement consoles
Table 2. Product Part Numbers Affected by This Announcement
Alex
03-13-2012 04:18 PM
Amanda,
HTH,
Chris
03-13-2012 04:27 PM
Hi Amanda,
Sorry but its gone
EOL Link
Alex
