Attendant Console LDAP: error code 49 in autogenerated.txt
Anybody know which user gets authenticated when the autogenerated.txt file is created when UCM 4.1 is AD integrated
The file contains
THIS IS AN AUTO GENERATED CORPORATE DIRECTORY LIST.
# Generated at: Tue Dec 02 08:31:25 CAT 2008
# ERROR: com.cisco.ac.server.ldap.ACLdapConnectionException: Cannot initialize directory context for: ldap://172.16.8.11:389 javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 52e, vece ]
Silver
Re: Attendant Console LDAP: error code 49 in autogenerated.txt
This problem may Caused by: java.io.FileNotFoundException:
/opt/cuma/conf/uma-prx.keystore (No such file or directory)
The keystore file should not be in the /root directory. The keystore file should be at /opt/cuma/conf/uma-prx.keystore
The first place to check is the /opt/cuma/logs/proxy directory on the proxy server. This contains the log files from the proxy service.
The most common problem that causes the proxy to fail to start is an invalid or improperly installed SSL certificate. Check that the certificate keystore file is installed in the correct location. The second most common problem is that the proxy can not communicate with the CUMA server's Admin port.
Dear Sir,
I have 2 of Unity Connection 7.0.1 servers (stand alone) and want to create cluster connection.
The servers ip address need to set at same VLAN segment if create cluster connection?
324
