Attendant Console License and configuration question
Does an Attendant Console require DLU's??Also, will Attendant Console plug in allow the attendant to have busy-lamp fields for all 150 stations??
Re: Attendant Console License and configuration question
Old AC does not require any licensing or DLUs, just the ones for the phones you use.
New ACs have a separate licensing but still phones are the ones that use DLUs?
Which one are you going to use??
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for the quick feedback. I believe we are going to use Java
240
