Community Member
Attendant Console - multiple calls on one line
I'm trying to find a way how one recepteonist can answer multiple calls on one existing line.
Scenario is -
Pilot Point that includes 2 members
Member_1_line 1
Member_2_line 1
Voicemail DN ( accept all other calls )
Sometimes we have a lot of calls and recepteonist should see them in AC as incoming call even if she is answerign another calls that moment. Both recepteonist should use only one line.
I have it working with hunt pilot - and is it possible to do the same with attentand console ?
Right now call coming to Pilot point goes to Member1_Line 1 and next call if it's busy try to go to Member2_ line 1. If both members busy - call forwarded to VM.
I want both recepteonist capable of answering couple calls oer line before call transfered to VM .
I see Cisco SRND guide and it says that this is possible - but not describe how
Based on the line settings on Directory Number Configuration window, Cisco Unified Communications Manager Attendant Console can support multiple calls on a line. When no more outgoing calls can be made on a line, Cisco Unified Communications Manager Attendant Console displays a warning message when the attendant attempts to make a call.
Any ideas ?
VIP Purple
Re: Attendant Console - multiple calls on one line
Adjust the Busy Trigger and Maximum Number of Calls fields in DN configuration to something greater than 1.
Hope this helps.
Brandon
Community Member
I have deafult settings for DN
MAximum number of calls - 4
Busy trigger - 2
When i make call to Pilot Point - this first DN is answering - and if at the same time i'm trying to call directly this DN - i see second call on it ..
But callign ot Pilot point ( to make second call on Member_1 line 1 ) doesn;t work ..
VIP Purple
One option would be to use multiple lines per user and configure the hunt group as follows:
Member_1_line 1
Member_2_line 1
Member_1_line 2
Member_2_line 2
Member_1_line 3
Member_2_line 4
VM
Brandon
Community Member
But i have only one line available on phone
if i configure Member_1_line 1
it's line 1 on the phone and
Member_1_line 2 it's anotehr physical line with another DN on phone , right ?
And i need call to come to the same hysical line , some DN
VIP Purple
Yes, this would require another DN on the phone. To my knowledge, this is not possible with only one line.
Brandon
Community Member
That's why i reference to CISCO SRND
VIP Purple
I believe this quote is in reference to outgoing calls.
Brandon
355
