Community Member
Attendant Console software
I am trying to find the latest software download for attendant console, but it appears, whenever I click on the link it puts me in a loop. Can someine please point me in the right direction, or post the link that will take me striaght to the download.
1 ACCEPTED SOLUTION
Re: Attendant Console software
if not 7.x, versions are specific, no new versions unless you patch the server.
7.X only provides AC if doing upgrade and was configured before, otherwise it's not provided
just go to download plugins from ccm admin
java
if this helps, please rate
java
www.cisco.com/go/pdi
Which version of CCM are you running?
Community Member
6.0
-J
I was just searching the voice software downloads section, and I think I hit the same loop that you did. Im not sure, but Im going to go out on a limb and guess that the version of attendant console that you have is dependent on the SR or ES verision of CUCM 6.x that you are running. Maybe someone else can confirm this.
Hope that helped.
java
java
233
