Attendant console Upgrade
i have a Cisco Unified Attendant Console Enterprise Edition 9.1, but it is incompatible with CUCM 10.5 that I am currently running.
I see that Cisco Unified Attendant Console Advanced version 10.5 is compatible with CUCM 10.5.
My Cisco Unified Attendant Console Enterprise Edition 9.1 is under a valid UCSS contract.
Is it possible to use this UCSS and upgrade from Enterprise 9.1 to Aadvanced 10.5?
been doing research and cant find my answer.
thanks.
1 ACCEPTED SOLUTION
If you're a partner, you can
If you're a partner, you can reach pre-sales for this kind of things.
java
if this helps, please rate
www.cisco.com/go/pdi
1 REPLY
java
87
