Attendant Console - Window to front on incoming calls
Hi - We are running CUCM6.1 and attendant console. Is there a way to stop the console fron popping up every time an incoming call arrives? I can't find any mention of it in the doco, but don't remember it donig it when using CCM4.1.
Thanks!
1 REPLY
Hall of Fame Super Red
Re: Attendant Console - Window to front on incoming calls
Hi Matt,
Have you tried to use this method to enable / disable "Pop to Top" on AC
Note: To toggle the pop-to-top feature on and off, press Alt + P.
From this doc;
http://www.cisco.com/en/US/products/ps7282/products_user_guide_chapter09186a00806cfff5.html#wp1007405
There is also another method listed nicely by Met (with screenshot) here;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbe64a0/2#selected_message
Hope this helps!
Rob
258
