12-30-2008 09:13 AM - edited 03-15-2019 03:16 PM
I need to configure our front desk so that calls can be placed to any 3 lines depending if one of the other lines are being used. I also need it to forward to a call handler within unity if she is not at her desk or it's off hours.
Currently
I have configured her phone in a hunt group for Attendant console and added all of her lines 2-4 then the last option is my route point that points to unity with a CFWALL to vm. The lines are configured to roll to the other 2 lines when busy/no coverage/ no answer etc.
Problem
When I call off hours and her attendant console is closed, everything works fine. But if she leaves her desk the call rings for 3 min then hangs up on the caller.
Question 1
Does she need to do anything with the attendant console when she leaves her desk?
Question 2
How are the lines on this phone suppose to be configured?
Question 3
Any ideas on how I might improve my current setup?
Solved! Go to Solution.
12-30-2008 09:51 AM
Simply configure the AC lines forward no answer to point to the same call handler DN, this way if she does not answer within the ring no answer timer the call will end up going the call handler.
HTH,
Chris
12-30-2008 10:10 AM
2 options:
1. Create a seperate VM Profile that masks the DN to the extension of the handler and apply this VM profile to the AC DNs.
2. Create forwarding routing rule in Unity that matches the DNIS of the AC line and sends it to the handler.
HTH,
Chris
12-30-2008 09:51 AM
HTH,
Chris
12-30-2008 10:05 AM
Thanks Chris! How do I get the line to foward the ext of the call handler instead of the line. When I look into Unity I show unity is receiving the line fowarding station not the call handler ext? Ideas?
12-30-2008 10:10 AM
2 options:
HTH,
Chris
12-30-2008 10:22 AM
Thank you Chris, Option 1 worked like a charm.
