Attendant Console
How can I have it stop popping up when a call comes in?
Re: Attendant Console
I think it depends on what version you are running. On mine, which is 6.1, there is a toggle button just to the left of the "Call Control Up" or "Call Control Down" on the bottom status bar which I believe turns off the feature that you want to eliminate.
On the bottom of the AC client there is a little button that controls whether AC will show in front of all other apps when a call comes in.
PLEASE search NetPro for answers before posting, this has been asked many times before (there are even some threads with the screenshot)
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Red
Hi Michael,
Here is another method to enable / disable "Pop to Top" on AC
**Note: To toggle the pop-to-top feature on and off, press Alt + P.
Hope this helps!
Rob
129
