Attendant Console
Can you stop Attendant Console from popping up on the screen everytime a new call comes in?
Chris
1 ACCEPTED SOLUTION
Re: Attendant Console
You can disable the pop up action on the ac client.
At the bottom of the AC window, there is a small icon just to
the left of the "Call Control" status indicator area. The icon
looks like a desktop window and if you click on it you can
toggle the "Activate console on new call" feature on and off.
I'm attaching a screen shot of the AC of my lab, indicating the
button I'm talking about.
1 REPLY
173
