attendence console
when using attendence console the error message appears "failed to transfer to voice mail"
Transfer to extention or directory listing works fine.
The attendence console service has been stopped and started, the pcs rebooted - the software installed without firewall
any ideas? many thanks in advance
Re: attendence console
version?
do the devices already have a VM profile?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Hi and thanks for the reply - the CM version they are using is 6.1 and yes theu have VM profiles set up
112
