Community Member
audio cuts out with CIPC & VPN
Have CIPC 2.0.2 with Cisco VPN Client v4.8 for windows.
CIPC works fine on LAN in office.
When in hotel with VPN running the audio seems to cut out occasionally and vpn client disconnects occasionally as well.
Have Toshiba P1000 winth XP patched up to latest with all drivers up to date.
Any help could be appreciated.
Paul.
Community Member
Re: audio cuts out with CIPC & VPN
If you are using AES encryption then you may be running into possible bug. Downgrade the VPN client to 4.0(5)D or use 3DES.
Community Member
Thanks - will try and advise.
Any idea what bug so i can check if and when it will be fixed?
Thanks again.
Paul.
Community Member
that did it as far as i can tell.
I've made several calls and no probs.
Thanks much for the assist.
Paul.
157
