Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
audio format for Unity Call Handlers
My customer has some professionally recorded greeting he wants to import into Unity Connection. They have the following properties:
Audio format...........PCM
Average Data rate......88.200 Kb/sec
Sample rate.......... 44.100 khz
Audio sample size.... 16 bit
Channels.............. 1 (Mono)
Unity does not except them. i can concert the properties with an app but I cannot find Unity's requirements. Can any one help?
Re: audio format for Unity Call Handlers
They should be
Bit rate 64 kbps
Audio 8 bit
Channels 1 (mono)
Audio sample rate 8 khz
Audio Format CCITT u-law
java
if this helps, please rate
java
www.cisco.com/go/pdi
You can use this software to convert to the required (see previous post) codec.
http://www.nch.com.au/switch/index.html
178
