auth fail 7911/06 load sccp41.8-3-1-s
i install load sccp41.8-3-1-s. may 7941/61 are ok but the 7911/06 make boot error. auth fail. after the boot continu. I want how to make boot correctly.
I dont have error with load SCCP11.8-2-1S. just with load SCCP11.8-3-1S and SCCP11.8-3-2S
Re: auth fail 7911/06 load sccp41.8-3-1-s
it lacked you to point the archive of loads in the Callmanager:
[Menu]
Device Settings >
Firmware Load Information >
Device Defaults Configuration >
Cisco 7911 = SCCP11.8-3-1S
good luck
You dont have error with load SCCP11.8-2-1S. Because all the archives of the package are complete. Go ties the site of the Cisco in Downlods software searching the image: cmterm-7911_7906-sccp.8-3-2SR1.exe - it could be found after executed in the way: C:\Program Files\Cisco\TFTPPath - in Server.
1270
