Community Member
Authentication error UCM 7 services
Cisco PD Authentication error is displayed when trying to access Personal Address Book or FastDials from Services button. Anyone ever seen this?
Re: Authentication error UCM 7 services
Have you checked that the services URL is not blank and that you have this type of URL:
http://servername-or-ipaddr:8080/ccmpd/login.do?name=#DEVICENAME#&service=f?d?
Specially if this was an upgrade from a 4.X version. Please check the bug below:
CSCso28287 Restore Fast Dials usage as a service on Linux, better than on Windows.
If this helps, please rate.
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
Community Member
Yes, I have that type as my service url. this is a new install of 7.02, specifically 7.0.2.2000-5
I copied the Service Paramenters, like UsrID, from my CM4 server. Maybe I dont need these anymore.
Yeah, Fast Dials and PAB changed, now they come embedded. If you have access to the bug toolkit you can check the bug notes:
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Teresa.
Community Member
I was reading some of the bug notes, I think the light bulb finally went on.
what I know of a CM4 FD and PAB accessed through the services, are now embedded as you said and are accessed through Personal Directories -directories- button, no longer -services- button
252
