02-23-2012 11:38 AM - edited 03-16-2019 09:45 AM
Hello
We have a PRI that the carrier requires user to enter a code when making long distance call.
user dial 1.212xxxxxxx get a tone from carrier then enter the pass code .
In SRST we configure the router to dial a number to access voicemail. The call will fail because carrier expect a passcode. How could I setup the
router to dial the passwode during SRST. Thanks
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.108.177.4 port 2000
max-ephones 58
max-dn 192 dual-line preference 2
system message primary Network Outage
dialplan-pattern 1 604408.... extension-length 4
transfer-pattern .T
voicemail 1415XXXXXXX
call-forward pattern .T
call-forward busy 1415XXXXXXX
call-forward noan 1415XXXXXXX timeout 15 call-manager-fallback
max-ephones 58
transfer-pattern .T
voicemail 14155412701
Mark
02-23-2012 08:11 PM
Hi Mark,
Configuration example below is not supported for PRI connections, but works (I used it in my lab to log into Unity Connection account with number 2001 and PIN 123):
telephony-service
voicemail 666
num-exp 666 0012012012100,,,*2001#,123#
dial-peer voice 666 pots
destination-pattern 0012012012100
port 0/0/0:15
forward-digits extra inband
Cheers,
Boris
02-24-2012 08:36 PM
Thanks Boris, I will try it next and provide
Mark
