Authorization code during SRST
Hello
We have a  PRI that the carrier requires user to enter a code when making long distance call.
user dial 1.212xxxxxxx get a tone from carrier then enter the pass code .
In SRST we configure the router to dial a number to access voicemail.  The call will fail because carrier expect a passcode.  How could I setup the
router to dial the passwode during SRST.  Thanks
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.108.177.4 port 2000
max-ephones 58
max-dn 192 dual-line preference 2
system message primary Network Outage
dialplan-pattern 1 604408.... extension-length 4
transfer-pattern .T
voicemail 1415XXXXXXX
call-forward pattern .T
call-forward busy 1415XXXXXXX
call-forward noan 1415XXXXXXX timeout 15 call-manager-fallback
max-ephones 58
transfer-pattern .T
voicemail 14155412701
Mark
Bronze
Hi Mark,
Configuration example below  is not supported for PRI connections, but works (I used it in my lab to  log into Unity Connection account with number 2001 and PIN 123):
telephony-service
voicemail 666
num-exp 666 0012012012100,,,*2001#,123#
dial-peer voice 666 pots
destination-pattern 0012012012100
port 0/0/0:15
forward-digits extra inband
Cheers,
Boris
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
Thanks Boris,  I will try it next and provide
Mark
278
