Authorization codes/Call Manager Express
Anyone know a way to restrict a low-end phone (7902, 7911, etc) from calling out of the CME but if a manager wants to use it, he can enter an authorization code to make the call.
The higher-end phones have a login button that does function similar to this but in our warehouse we use the 7902 and 7911 phones.
Thank you.
Re: Authorization codes/Call Manager Express
You might me able to accomplish this by creating an after-hours block pattern, exempting all phones but the warehouse phones and placing a pin number on those phones which you give to the managers.
telephony-service
after-hours block pattern 1 9 7-24
ephone 1
after-hours exempt
ephone 2
pin 12345
http://www.cisco.com/en/US/docs/ios/12_2/12_2z/12_2zj/cme30cr/icr30am.html#wp1007475
Jesse
Hall of Fame Super Gold
Another alternative is that you configure a DP with pin-like digits to place before the number, so only people that know it can dial out.
Then you would configure COR to restrict the other DPs and make effective the above.
145
