Auto add 9 from Missed Calls section
Is there any way to auto-add a 9 or 91 when you hit dial from a the missed call section?
The only way I can think of is a pattern of 2-9[XXXXXXXXXX]
1 ACCEPTED SOLUTION
Re: Auto add 9 from Missed Calls section
Hello:
Which version of call manager are using? If you are using call manager 3.3 later you would need to add in the service parameters
Refer to this document, for more clarification.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
Hello:
Using 6.1(2) with MGCP gateway.
I couldn't find the service parameters uder the MGCP / PRI Gateway section in our CCM cluster, I implemented the translation pattern fix and it seems to be working great.
Thanks!
Can you share the TP fix that you implemented in resolving the missed calls dialing issue.
the link on the very first response has the instructions on how to create the translation pattern, have you looked at it??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
197
