Community Member
Auto Answer not working for 7965 IP phone
We recently went live with our new call center. All agents are using IP Communicator with Plantronics WO100 headsets. We are able to get the auto-answer feature to work fine for the agents. For the supervisors (use 7965 hard phones), however, auto answer works but outbound audio does not. We can hear the call coming in and can hear the person talking but they can not hear us. Please advise. Thanks!
Re: Auto Answer not working for 7965 IP phone
Do you have Auto Answer set to use the headset or speakerphone? What version of CUCM and phone firmware is in use?
-Felipe
Community Member
Hi Felipe,
     We have Auto-answer configured on the DN in CUCM and then have the headset light active on the hard phone. We are CUCM version 6.1.2.1112-2 and firmware SCCP45.8-4-4S. Auto-answer works with IP Communicator but not the deskphones. Thanks!
Felipe is asking if it is set to auto answer with speakerphone or headset: http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_0/english/user/guide/75706545dev.html#wp1012251.  While the 7965 does answer, if it was speaker phone I would assume that the other party would still be able to hear the answering phone if it was on speaker.  One question here, if you make a normal call with the headset, do you have to turn on the headset first then place the call with the headset selected?  The headset won't be told to auto turn on or answer, only the phone will, possibly causing the one way audio issue, just a guess.
Community Member
Auto Answer is set to Auto Answer with Headset in the directory number settings.
Normal call does not require the headset button to be on.
Thank for your help.
Are you using headsets with the 7965 ip phones or the handset?
-Felipe
1611
