Auto answer with FXO or FXS port
I have a paging system that used to connect to an analogue port on a PBX.  The analogue port was configured for auto answer.  When you called the port extension from any phone you could make announcements over the paging system.  We have now implemented Cisco IPT and I need to recreate this capability.  I need to be able to configure either an FXS or FXO to auto answer when this extension is called.
Hall of Fame Super Gold
Maybe start which system and version are you using, which gateway and which protocols are you using.
We are running CUCM 6.1.2, the gateway is configured to use H323 and is a  3925 running c3900-universalk9-mz.SPA.151-4.M1.bin
Hi Michael,
for auto-answer use command "connection plar"
1227
