Auto Answer
When I am in CM and try to set Auto Answer to with speaker phone I get a message that says "Update Failed. Auto Answer feature is not supported for this device...."
I have my phone and upc.
Hall of Fame Super Red
Re: Auto Answer
Hi Tamera,
It sounds like the IP Phone model does not have a full Speakerphone capability. What model are you trying this with? Auto Answer also does not work with Shared Lines :)
Cheers!
Rob
Hello...I am having the same
Hello...
I am having the same issue and my phone model is 7965. Any help would be great.
Thank You...
Hi Rohan,Can you share the
Hi Rohan,
Can you share the cucm version , phone firmware version and screenshot of the error?
Manish
990
