Auto Attendant- call get forwarded to a mobile number when a customer press option 3 for example.
Can someone please help, I have Auto Attendant setup and when a customer ring after 5pm when the company close, the call get forwarded
to a manger mobile number, can any one please show me where I can change the forwarding in CUCM?
Thnaks
Re: Auto Attendant- call get forwarded to a mobile number when a
You don't change it in CUCM, your AA isn't there.
Where is your AA??
Or maybe I'm not getting it, do you only want to change the forwarding from the DN??
Or the option in the AA??
java
if this helps, please rate
www.cisco.com/go/pdi
I think it is in the AA but I don't know how to access it because I dont know where to find it, is it in the same GUI as the CUCM?  Many thanks
No, its not the same GUI. You should know where your AA is running.
If youre not familiar with the system, and change something else, you might break it, get in touch with your local IT for this.
java
133
