Community Member
Auto Attendant/Greetings Question/Help!!!!!
The configuration of our AA is;
A person Calls in the main number and is asked to make one of several selections. Some go to sub-menus, and others go directly to a hunt group.
I was asked to change one of the selections but I not sure how/if I can do what I would like to do.
Currently the way this menu works is call main number->AA answers->person presses 1->AA puts them in a hunt group
What they want to do is; call main number->AA answers->person presses 1->a short informational message plays->release to hunt group
I know how I want to do it, but I can't see where I actually CAN do it. The only way I can see to do it is to add a CTI and point the first pressed key (1) to the new CTI->have the recording on that CTI and at the end of the recording tell them to press 1 (AGAIN) to be dumped into that hunt.
Is there a way to: call main AA->user presses selection->play additional message->then release to hunt group without input?
I would appreciate any help!
Unity Connection/CUCM 8.6
Everyone's tags (3)
1 ACCEPTED SOLUTION
That is fine....you can still use the same setup that i mentioned
caller reaches main AA => presses 3, which sends call to greeting for call handler #2 which will play the message..on call handler 2, set the after greeting action to send to call handler #3. Call handler 3 will not have a greeting...just a transfer option which sends the call to the hunt group extension.
This should be possible with the use of 3 call handlers.
1. The first call handler is the main AA that callers will hit when calling the main number.
2. The second call handler will play the informational recording
3. The third call handler will transfer the call to the hunt pilot extension.
Caller calls main AA => presses 1 => sends call to greeting for call handler #2..on the after greeting action for this call handler, set the call to attempt transfer for call handler #3...on the transfer options for call handler 3, set that to the hunt pilot extension.
Hope that helped, if so please rate.
Community Member
Re: Auto Attendant/Greetings Question/Help!!!!!
I guess I need to clarify a bit.
example:
Caller calls main number:
AA menu options
press 1 for engineering
press 2 for accounting
press 3 for marketing
callers wanting to get to maketing press option 3-> then the message should play for those people trying to reach marketing
i.e. "we are having a marketing competition this quarter please ask the next accociate for detials"
release to hunt group.
Sorry for the confusion
Community Member
Got a bit confusing since I have never done this, but I have the framework built, and will record and test this coming week and report back.
Thanks alot....even more so if this works. It makes sense though. It was the transer rules that stumped me.
OK...let us know how it goes.
Community Member
Worked like a charm. Thank you so much. You are awesome my friend.
422
