Auto attendant login
I would like to check the login and logout time of my receptionist who is using attendant ID and password.
Is it possible to track the login and logout details in date wise?
Please rever, if you require any more details.
Thanks.
Re: Auto attendant login
do u mean attendant console?
what CUCM version?
java
if this helps, please rate
www.cisco.com/go/pdi
Yes, Attendant Console.
CM Version:4.1(3)
you should be able to look this in the TCD trace from the node on which they log
java
If you enable the perfmon tracing, you should be able to see logged in/out status.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_1_1/nci/ssrtmtpm.html#wp1034678
Link for 5.x but you can search for 4.x
126
