Auto attendant on BRI
Have too incoming lines one standard line into an fx card.
When the route recieves a call on this my AA picks up and ask which extension is required. This is fine
The other line is a BRI connection. When the number for this is dialed the AA doesn't answer and the call is disconnected?
dial-peer voice 9 pots
description PSTN
service aa
destination-pattern 9.T
incoming called-number .
direct-inward-dial
port 0/1/0
dial-peer voice 8 pots
description ISDN
service aa
destination-pattern 8.T
direct-inward-dial
port 0/0/0
Can any one advise Why this is?
Here is my
debug isdn q931:
*Apr 19 12:57:45.367: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Called Party Number i = 0x81, 'ISDN number'
Plan:ISDN, Type:Unknown
*Apr 19 12:57:45.407: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
*Apr 19 12:57:45.435: ISDN BR0/0/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Channel ID i = 0x89
*Apr 19 12:57:45.487: ISDN BR0/0/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0
*Apr 19 12:57:45.491: %ISDN-6-CONNECT: Interface BRI0/0/0:1 is now connected to
N/A N/A
*Apr 19 12:57:47.219: %ISDN-6-DISCONNECT: Interface BRI0/0/0:1 disconnected fro
m unknown , call lasted 1 seconds
*Apr 19 12:57:47.219: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8090 - Normal call clearing
*Apr 19 12:57:47.379: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
*Apr 19 12:57:47.383: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x
81
debug voice dialpeer:
*Apr 19 13:05:59.447: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=ISDN number, Voice-Interface=0x476533FC,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
*Apr 19 13:05:59.451: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=9
Calling Number=, Called Number=ISDN number, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
Result=NO_MATCH(-1) After All Match Rules Attempt
*Apr 19 13:05:59.487: //-1/8D5EA6628004/DPM/dpMatchPeersCore:
Calling Number=, Called Number=ISDN number, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=650372
*Apr 19 13:05:59.491: //-1/8D5EA6628004/DPM/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Apr 19 13:05:59.491: //-1/8D5EA6628004/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
*Apr 19 13:05:59.567: %ISDN-6-CONNECT: Interface BRI0/0/0:1 is now connected to
N/A N/A
*Apr 19 13:06:01.291: %ISDN-6-DISCONNECT: Interface BRI0/0/0:1 disconnected fro
Hall of Fame Super Gold
Re: Auto attendant on BRI
hi Martin,
first, your DP 8 needs "incoming called-number", not "destination-pattern". You can also remove the "port", as it not used anymore for incming DPs.
Then, the number called needs to match AA param aa-pilot. This means either you configure another AA different from the POTS, or setup things so that the pilot is the same, what are you using for aa-pilot now ?
I'm using DP 8 and 9 to get outside line from VoIP phones. So the user dials 8 to access the ISDN line and 9 to use the standard phone line
If I remove destination pattern from DP8 wont that stop me being able to press 8 for an outside line?
Yes, because you have configured a combined inbound and outbound DP. When configuring more than very basic is sometime necessary to keep them separate also for clarity in the configuration. When you add a DP with "incoming called-number", (your "ISDN number" in the debug posted), or a pattern that covers it, that will start triggering aa.
But I was referring to the param for the script, because it need to match, what are you using now as "param aa-pilot" ?
I have attached my router configs if that helps?
Hi, i'm not familiar with the script you are using, I thought you was using AA-BACD. If the latter, the configuration would be incomplete.
Anyway, AA should work as soon you make a DP with "incoming called-number".
107
