Auto-Attendant Problem
Good day all,
I have the following problem.
I am trying to configure the auto-attendant in Call Manager Express 7.0, Cisco Unity 3.1
I have configured the following:
On Cisco Unity:
ccn trigger sip phonenumber 191
application "autoattendant"
enabled
maxsessions 4
end trigger
ccn application autoattendant aa
description "CiscoAutoAttendant"
enabled
maxsessions 4
script "aa.aef"
parameter "dialByExtnAnytime" "false"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "dialByExtnAnytimeInputLength" "4"
parameter "operExtn" "110"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "true"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "false"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "businessSchedule" "systemschedule"
parameter "MaxRetry" "3"
end application
On Call Manager
dial-peer voice 301 voip
destination-pattern 191
session protocol sipv2
session target ipv4:11.0.0.30
dtmf-relay sip-notify
codec g711ulaw
no vad
When I am calling from my ip phone the 191 extension I can hear the "welcome to the automated attendant". Press 0 to call the operator number, or the extension. When I press an extension the phone rings.
But what I want is when somebody calls our company to first hear the auto attendant.
How can I configure the call manager to match the auto-attendant number with the called number?
Thanking you in advance.
Ioanna
1 ACCEPTED SOLUTION
Re: Auto-Attendant Problem
Yes, that is correct.
Brandon
What is your PSTN connection. If POTS coming into an FXO port, you can configure the "connection plar" command under the voice port, such as:
voice-port 0/0/0
connection plar 191
If PRI/SIP, you can use a voice translation rule:
voice translation-rule 1
rule 1 /1234567890/ /191/
voice translation-profile 1
translate called 1
dial-peer voice 1 pots
incoming called-number .
translation-profile incoming 1
Hope this helps.
Brandon
I have the following configuration:
voice translation-rule 800
rule 1 /024000/ /100/
rule 2 /024001/ /101/
rule 3 /024002/ /102/
rule 4 /024004/ /104/
rule 5 /024007/ /107/
rule 6 /024008/ /108/
voice translation-rule 900
rule 1 /024010/ /110/
rule 2 /024011/ /111/
rule 3 /024012/ /112/
voice translation-profile profile
translate called 900
voice translation-profile profile1
translate called 800
voice translation-profile profile2
translate called 700
voice-port 0/2/0
translation-profile incoming profile1
compand-type a-law
cptone GR
bearer-cap Speech
voice-port 0/2/1
compand-type a-law
cptone GR
bearer-cap Speech
voice-port 0/3/0
translation-profile incoming profile2
compand-type a-law
cptone GR
bearer-cap Speech
So, how can I change the configuration?
Depending on which voice port the call will come in on and what the called number will be, change the corresponding translation rule. So, if the called number were 024009 coming in on port 0/2/0, you would add the following:
rule 7 /024009/ /191/
Hope this helps.
Brandon
I would like that when somebody calls the 024000 to hear the auto attendant welcome promt.
If somebody knows the internal number to dial it.
So, I think that I have to change only the following...
rule 1 /024000/ /191/
And, operator number will be the 100.
parameter "operExtn" "100"
Am I right???
Brandon
Thanks!!!!
I made the changes and it is OK!!!!
Thank you!!!!!!
365
