Community Member
Auto attendant without a server? Options?
Hello folks,
Imagine I have 95 Cisco IP Phones and users.
I need to provide capability to let 1 operator to manage (transfer) calls, etc.
I see that if I deploy Cisco Unified Auto Attendant Enterprise, Business or Department I would need to provide a server.
I didn't include money for server in the budget, so at the moment  I can't do that.
Please advise if I have workarounds to get auto attendant functionality without buying a whole server to support it. I have only a WIn7 Pro PC.
Marlon
Blue
Hi Marlon,
If you do not want to invest on any extra hardware, You can use transfer facility on one phone which will make auto attendant functionality. But you will not get most of the Auto attendent feature.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Silver
Re: Auto attendant without a server? Options?
VistaPoint console is PC based and I've heard very good things about it in compatison to CUEAC.
http://www.iqnetsolutions.com/Cisco_MainPage.htm
HTH,
Chris
VIP Super Bronze
Well the CUDAC software can be installed on a workstation, so there's that route. Additionally, you could possibly use CUPC/Jabber in deskphone control mode.
Otherwise there are a few third-party options (in no particular order):
1444
