09-18-2008 04:25 AM - edited 03-15-2019 01:22 PM
I finally implemented cisco unity express.Thanks you.
When i call the receptionnist pstn line i want the auto attendant to give me some options like press 0 for operator.How do i do this?
Solved! Go to Solution.
09-18-2008 04:51 AM
Hi Kolawole,
Great work so far! Just wanted to added a little more reading material to the good info posted up by my friend Marwan;
Cisco IPC Express System Configuration Example
Configuring the AA
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/CP_CIPExpress/cipce15.html#wp1011557
Auto Attendant Design Considerations
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/design21/cueaades.html
Configure and Manage the Cisco Unity Express System Auto Attendant
Troubleshooting Cisco Unity Express Automated Attendant
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/CP_CIPExpress/cipce20.html
Hope this helps!
Rob
09-19-2008 01:58 AM
Hi, The configuration for AA in CUE is the same for CUCM and CCME. Please follow the example provided by our dear friend Rob.
Chandrasen
09-18-2008 04:30 AM
have a look at the following config example very helpful:
good luck
if helpful Rate
09-18-2008 10:00 AM
I am using a call manager 4.1.I think your answer applies to call manager express.Could you provide a way to do it with call manager ?
09-18-2008 04:51 AM
Hi Kolawole,
Configuring the AA
Hope this helps!
Rob
09-22-2008 05:49 AM
09-18-2008 06:10 AM
Thanks.Remember that i am using call manager with mgcp protocol not call manager express.I think your exemple applies to call manager express.Am I wrong ?
09-19-2008 01:58 AM
Chandrasen
