Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
auto attendant
I am a little confused about auto attendant. Is it possible to do auto attendant on a callmanager only? Or do you have to have Unity / Unity Connection / Unity Express also to do auto attendant? Also, I tried to find documentation to show me how to do auto attendant on a callmanager, but I cant seem to find anything on it. I guess thats why Im thinking you have to use a Unity product for this? Can someone clarify for me please?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: auto attendant
Hi Mike,
With CCM (all versions), they do ship with a "stripped down" version of IPCC/CRA which is where the actual AA is built (if you are not using Unity/Unity Connection/CUE).
Cisco CallManager AutoAttendant
Cisco CallManager AutoAttendant, a simple automated attendant, allows callers to locate people in your organization without talking to a receptionist. You can customize the prompts that are played for the caller, but you cannot customize how the software interacts with the customer.
Cisco CallManager AutoAttendant comes bundled with Cisco CallManager on the Cisco CallManager Extended Services CD. This version of Cisco CallManager AutoAttendant provides a four-CTI port limit. If you need a fully configurable automated attendant, you will need to purchase Cisco IP Interactive Voice Response (IP IVR), one of the Cisco Customer Response Applications (CRA).
This chapter describes Cisco CallManager AutoAttendant that is running on Cisco CallManager 4.1 with Cisco CRA 3.5.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsaa.html
Hope this helps!
Rob
Re: auto attendant
Hi Mike,
Hope this helps!
Rob
Re: auto attendant
Thanks. That is good information.
Re: auto attendant
With Windows-based CallManagers is possible to run AA on the same server wth CallManger,
with Linux-based CallManagers(5 version and more) you need separate server.
Re: auto attendant
Hi Mike,
You are most welcome my friend!
Take care,
Rob
PS: Not sure if you saw the reply regarding CCM Upgrade times. (FYI)
Re: auto attendant
No, I didnt see the estimated times it might take to do an upgrade like this. Can you point it to me or let me know?
Re: auto attendant
293
