Auto attentand in CME 8.6
Hi!
I want to know if is possible configure a IVR in a CME 8.6 with ephones 6921 sccp.
I found the auto attendand feature, but is it possible in cme 8.6? when an incoming call arrives, a locution must indicate for X department press 1, 2 for another and so on, is it possible? and how can i reach this?
Thanks & Regards!!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Just enter B-ACD/AA in cisco.com search box and you will obtain all the links.
From there you can read and learn how to do the prompts.
Yes, that is called B-ACD/AA,
Hi!
Could u give me the link to configure it?
And do i need to record previously the messages and copy them ti te flash?
Thanks!!
ok
thanks!!
Thank you for the nice rating and good luck!
555
