09-26-2008 11:11 AM - edited 03-15-2019 01:34 PM
Does auto qos automatically enabled the priority out command when enabling it on a switchport.
See config below - priority-queue out is missing. Does it need to be added with auto qos?
interface GigabitEthernet1/0/1
switchport access vlan xxx
switchport mode access
switchport voice vlan xxx
switchport port-security maximum 2
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust device cisco-phone
mls qos trust cos
macro description cisco-phone
auto qos voip cisco-phone
spanning-tree portfast
10-01-2008 08:06 PM
Auto-qos command does not automatically enable the priority out command
The expedite queue is a priority queue, and it is serviced until empty before the other queues are serviced. You enable the expedite queue by using the priority-queue out interface configuration command.
10-02-2008 03:28 AM
Yeah, thats what i thought. Thanks.
