Auto Ring Feature Possible?
I have a phone, that when the hand set is picked up, I want to automatically dial an extension. This phone will only be used to dial this extension when the hand set is picked up. We are running Call Manager 6.1. Is this possible, and if so, how does one set this up?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Auto Ring Feature Possible?
Hi Adam,
Just to add a note to the great tips from Nick (+5 points Nick :)
There is a great step by step here;
Hotdial on IP Phones with CallManager Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml#intro
Hope this helps!
Rob
What you do is create a CSS that contains a single translation pattern that translates 0 digits into the number you want to dial.
Here are the specific steps:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_3/cucm-rel_note-613.html#wp472214
hth,
nick
Hi Adam,
Hope this helps!
Rob
104
