Community Member
AutoDial
Hi.
I have a solution with CCM cluster(2) and same SRST in same sites.
When the customer press new call and not dial any digits, after the timeouts, the ip phone autodial to unknown number and after the call change to DN in local site!
Why?
VIP Super Bronze
Re: AutoDial
This is really interesting!!!! Never seen or heard that before!!!
What version of CCM are you using? I hope its not CCM 5.1.3
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Re: AutoDial
System version: 5.1.3.2000-3
VIP Super Bronze
Re: AutoDial
Well, Lots of bugs have been reported on this ccm version..
May be its a bug!
Re: AutoDial
do you have a blank translation pattern in there???
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: AutoDial
I have 2 translation-pattern
11.! in PT_JRBTB_Local
11.! in PT_ADumas_Local
Re: AutoDial
ok, so it might not be a translation pattern. not sure of your version but have you tried deleting all the unassigned DNs??
if you run a route plan report do you see anything blank??
javalenc
java
Community Member
Re: AutoDial
No.
See attach, please.
Community Member
Re: AutoDial
More Attachments
Re: AutoDial
you would need to enable a CUCM detailed trace to look into this
javalenc
java
Community Member
Re: AutoDial
When I delete the dn or change his partition, all fine ok!
The problem is in DN 9587!
Re: AutoDial
weird, only a trace would tell what happens. maybe something in cache memory, have you tried a cluster reboot??
javalenc
java
228
