Automatic call forwarding (time based) to mobile number in CUCM 9.1.1
W S H FERNANDO
Level 4
Level 4
I need to configure time based automatic call forwarding to mobile number. Can we do this from CUCM 9.1.1 ?
Example : Ex 2000 need to forward to 01111188888 in every friday after 9.00pm
Regds
Manish Gogna
There is no such specific option at the DN level, you need to turn on and turn off the call formward all option manually. However, you can check the Time of Day Routing option if it fits your requirement as described in the following doc
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/109588-tod-routing-example00.html
Manish
Rajkumar Yadav
Level 4
Level 4
There is one way you can still achieve it by using the Mobile connect (SNR).
In the Remote Destination you have the option to ring your mobile based on your requirement.
Please see the attached screenshot for the same.
So user need to enable the Mobile connect on friday all calls will go to the Mobile phone # (Remote destination).
Also delay before ringing should be 0 ms.
Please refer to the Mobile connect configuration guide for the same.
Kind Regards,
Raaj.
Chris Deren
You can build another 2000 DN in ToD parition that is set to call forward to the desired destination at specific time of day/day of week, make sure this parition is listed above the normal phone DN parition so it gets matched first.
Chris
