Automatic conference feature in Call Manager?
Hi All,
Is there any way I can push the button on the phone and then it will automatically call several people and conference them in? Is there anything I can program in call manager to get this feature done?
Thanks.
Lou
No, that's not something you can do with CUCM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks Java. So what system do I need for that feature then? UCCX?
Lou
Hall of Fame Super Silver
UCCX cannot do conferencing, you would need some custom development to archive that, i.e. XML service that somehow accomplishes that.
Chris
Thanks Chris. Is there any documentation to describe XML service in call manager? That might be the way I need go. Thanks.
Lou
This should get you started:
Cisco Unified Communications Manager  (CallManager)
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
java
java
280
