Automatic dialing when a phone goes off-hook
We have some phones in the corridor of a shop which are used by the customers to contact to the operator (hunt group 1090, with two extensions, 1000 and 1001). I would like to configure the phones to dial directly to 1090 (or 1000 if it doesn't work) when the phone goes off-hook. If it is not possible, could I configure a direct access (for example dialing 0) to connect to 1090 or 1000? The CCM version is 5.1(2).
Best regards.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Automatic dialing when a phone goes off-hook
Hi Victor,
The step by step directions in this guide are very good (the principles should carry over nicely) :)
Hotdial on IP Phones with CallManager Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
Hope this helps!
Rob
I think the best way for u is to use PLAR ( Private Line Autmatic Ringdown ) pointing to your hunt pilot.
Hello, thank you for your response. The problem is that the phone in which I want to configure the automatic dial is an analogue phone attached to a FXS port in a 2851 and MGCP-controlled. So I think I can't configure PLAR in Call Manager (this functionality is for IOS Gateway).
Regards.
Hi Victor,
Hope this helps!
Rob
Hi Rob, thank you for the useful information, it is exactly what I need. I tried to do that, but I think it did not work because of partitions and CSS. Now it is working perfectly.
Best regards.
408
