Automatically send car reports?
Hi!
Like the headline states, is there a way to do this?
As it is now, I go in and manage to email a report and all is well - it seems like it should be possible to send the reports automatically, but is it ?
regards
Björn
Bjorn,
Check out " Enabling or Customizing Reports for Automatic Generation "
GP.
Pls rate helpful posts by clicking on stars below the post !!
Some of the reports might be sent automatically to the CAR Administrators, CAR Manager and CAR users. The above link should be helpfull configuring it. Be carefull if you are using LDAP and CUCM has all your company users email, on the type of reports you enable to minimize the audience of the reports to the intended ones.
168
