ā08-29-2007 11:18 PM - edited ā03-14-2019 11:18 PM
This should be an easy question, but a search of Cisco doesn't seem to pull up the answer.
The AUX port on the back of 7960 IP Phones isn't really mentioned in any of the 7960 documents. What is it actually used for?
What sort of implementation/setup would require or use the AUX port?
Is there any documentation on this?
I came across a few Analog Polycoms plugged into the AUX port today. I'm almost certain it was a mistake by the cabler, but still it got me thinking...
Thanks for your help!
Solved! Go to Solution.
ā08-30-2007 01:18 AM
7960 AUX port is commonly used for connecting Cisco 7914 Expansion Module.
Some info about other devices that could be connected to AUX port you can find in "Lantronix Application Extension SDK for Cisco IP Phones.doc" delivered in IP Phones Services SDK.
regards,
PK
regards,
PK
ā08-30-2007 04:25 PM
Thanks PK.
I feel a little silly now - I should have remembered that it was for a 7914... I installed one a while back.
The only mention of the AUX port is in this document about 7914 expansion modules, which is a PDF (http://www.cisco.com/application/pdf/en/us/guest/products/ps1856/c1626/ccmigration_09186a00802def03.pdf), so I guess that's why my search on Cisco.com didn't reveal anything.
Thanks again for your help on what was a silly question :)
David
ā05-10-2011 06:14 AM
hi all,
AUX port is also used to connect the wireless adapter to 796x,794x,797x series phones.
This wireless adapter helps to synchronize the plantronics c50 , c70 series wireless headsets for 796x,794x,797x
good day....
