Avaya 9600 phones on Catalyst 3560
Have a question regarding some issues when running Avaya 9600 phones on my 3560 switches. Under normal circumstances, our IP phones work properly when we manually tell the Avaya phone what vlan it should be in. We use these commands on the ports that have the 9600 phones:
interface GigabitEthernet0/3
description IP Phone
switchport access vlan 16
switchport mode access
switchport nonegotiate
switchport voice vlan 204
spanning-tree portfast
The problem is when I completely erase all the phone settings, or add a new phone out of the box to one of these switchports, the phone will not properly boot up until I manually add the vlan information into the phone. We had a power outage recently where when the power came back on, many of the ip phones lost their vlan information, and we had to manually walk to each desk to put in the vlan information so they could boot up. Wanted to know if there was some work around to this that anybody has experience who has a similar environment.
Re: Avaya 9600 phones on Catalyst 3560
From the information that you have provided the configuration of the IP Phone is done manually not via dhcp?
Apparently it is possible to assign the VID using DHCP and configuring DHCP option 176, which contains a string such as the following:-
L2QVLAN=7 In this example L2QVLAN is configured VID 7.
Take a look at this post:-
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Video%20over%20IP&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1888a/0#selected_message
Rgds
Allan.
Pls rate helpful posts..
Yes, we are using dhcp, and we are using option 242 with the information that you mentioned. Upon further troubleshooting, I discovered that I needed to put that string in option 242 in both the voice vlan, as well as the corresponding data vlan.
DHCP Option 242 is for the Avaya 9600 as you have pointed not 176.
Please take a look at the following thread that I came across, not sure if will help, but it refers to details being dropped if the string is not configured correctly.
http://www.avayausers.com/showthread.php?t=15240&highlight=dhcp
Rgds
Allan.
Pls rate helpful posts...
1239
