Avaya ACM to CUCM/CME via CUBE (IP2IP Gateway)
We are trying to connect an Avaya ACM trunk to CUCM/CME thru a CUBE (IP2IP Gateway)via H.323
We can successfully make calls from the CUCM and CME via the IP2IP Gateway to the Avaya ACM but we can NOT make any calls from the Avaya to the either CUCM and CME. A sniffer trace indicates a "Cause No. 38 - network out of order."
Config Snipet:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
signaling forward unconditional
h323
emptycapability
h225 timeout t302 15
h225 signal overlap
h225 connect-passthru
modem passthrough nse codec g711ulaw
VoIP Dial-Peer are defined
I looked at some other posts but didn't find anything that stood out. Any help would be appreciated. Thanks!
1 REPLY
Re: Avaya ACM to CUCM/CME via CUBE (IP2IP Gateway)
I have attached a Debug Trace.
475
