Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Avaya Phones drops every third packed when do the extended ping
I am seeing Avaya Packed drops every third packed when do the extended ping from router or switch. Anyone has any idea about this behaviours?
Switch#ping 10.10.10.1 repeat 20
Sending 20, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hi Pawan,
This is normal due to the DOS prevention mechanizm on the CM.
JP
Hi Pawan,
JP
Hi JP,
You are correct. I have also found same info in Cisco docs.
"This is because the IP phones have been designed to only reply to an echo
every 10ms, in order to withstand Denial of Service (DoS) attacks. DoS
protection is provided by limiting resources for ICMP processing and not
responding to ICMP broadcast pings. A Cisco IOS gateway sends echos more
frequently, so will timeout.This is not the case for a PC since the time
between two echos is greater than 10ms"
Hi Pawan,
Yes, you are right
1341
