AXLSQL Update line display getting error
update devicenumplanmap
set display='WHS Dialysis Isolation Room 2'
from numplan where numplan.dnorpattern='33722'
and devicenumplanmap.fknumplan=numplan.pkid
CUCM ver is 6.1.2 and AXL code as follows
<?xml version="1.0" encoding="UTF-8"?>
<!--DTD generated by XMLSPY v5 rel. 4 U (http://www.xmlspy.com)-->
<!DOCTYPE data [
<!ELEMENT data (sql+)>
<!ELEMENT sql EMPTY>
<!ATTLIST sql
query CDATA #IMPLIED
update CDATA #IMPLIED
<data>
<sql update="update devicenumplanmap set display='WHS Dialysis Isolation Room 2' from numplan where numplan.dnorpattern='33722' and devicenumplanmap.fknumplan=numplan.pkid"/>
</data>
Getting the following error:
<?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Header/><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</faultcode><faultstring>A syntax error has occurred.</faultstring><detail><axl:Error xmlns:axl="http://www.cisco.com/AXL/API/1.0"><axl:code>-201</axl:code><axl:message>A syntax error has occurred.</axl:message><request>executeSQLUpdate</request></axl:Error></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
233
